System error. Code: 1400 Invalid window handle
user2088
Europe
Hi Community,
there is a reproducible issue using the function "Keep remote directory up to date":
After running mentioned function (details in screenshot) WinSCP will unexpected break after a few days with error message "System error. Code: 1400 Invalid window handle" and the synchronization will stop. Users can start again and it will run for another few days. But it will break again.
How could it be fixed?
Thanks for investigation.
Re: System error. Code: 1400 Invalid window handle
From the names of your screenshots, I assume you get the problem (only?) when running WinSCP via TeamViewer. Is that correct?
