Decrypt local file
dajkamienia
Decrypt local file
Hi
I just started to use WinSCP, could you advice if there is any option to encrypt/decrypt local files?
I have home SFTP so I can access them straight away. It would be better to encrypt/decrypt locally without sending them through WiFi with small speed.
Regards
Re: Decrypt local file
What does encryption (and what kind of encryption?) have to do with the "small speed"? Don't you want to compress the files instead?
