Script works standalone but not in Windows Task Scheduler?
richardcav
Spain
Hi, newbe here so sorry if this is a stupid question, I have a script that builds a .dat file that gets uploaded by winscp.cmd, the script is...
@echo off
echo open sftp://username@IP/home/domain/public_html/ -hostkey="key" -privatekey="Key" -passphrase=phrase >> ftpcmd.dat
echo put xmlfile.xml >> ftpcmd.dat
echo exit >> ftpcmd.dat
"C:\Program Files (x86)\WinSCP\winscp.com" /script=ftpcmd.dat
del ftpcmd.dat
...and it works perfectly when I execute fileup.bat (the name of the batch file), but when I try to schedule that same batch file, it doesn't work – it runs and stops straight away.
Can anyone please tell me what I'm doing wrong?
Regards
Richard
