Get the status of PutFile
abellos
first time that use the library. I have a cycle to upload file on an SFTP server.
This is my code
If Session.Opened Then
    Try
        CONN.Open("Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & PercorsoDB)
        SQL = "SELECT percorso, nomefile, est FROM gestioneIMG WHERE Invio >= 44866 and Invio <= 44870"
        RS.Open(SQL, CONN, ADODB.CursorTypeEnum.adOpenKeyset, ADODB.LockTypeEnum.adLockOptimistic)
        ' Upload files
        While Not RS.EOF
            nomePdf = RS("nomefile").Value.ToString & "." & RS("est").Value.ToString
            Percorsopdf = RS("percorso").Value.ToString & nomePdf
            PercorsoRemoto = "/test/08439/upload_scansioni/F01/ORIGINAL/"
            If Not Session.FileExists(PercorsoRemoto) Then
                Session.CreateDirectory(PercorsoRemoto)
            End If
            StreamFile = File.OpenRead(Percorsopdf)
            Session.PutFile(StreamFile, PercorsoRemoto & nomePdf, transferOptions)
            txt.Text = txt.Text & vbCrLf & "caricamento" & nomePdf
            RS.MoveNext()
        End While
        RS.Close()
        RS = Nothing
        CONN.Close()
        CONN = Nothing
        MsgBox("File caricati")
    Catch exc As Exception
        MsgBox("Errore" & exc.Message)
    End Try
Else
    MsgBox("session chiusa")
End If
How can I know if the file is uploaded correctly? With PutFiles there is the TransferOperationResult class, for single file there is some similar?
