Connection Failure to Certificate
Hospital
I am trying to connect to our server using a script file but unsuccessful. When connecting thru the program and manually accepting the certificate, it works. Appreciate any help.
Log file:
. 2022-12-06 12:42:13.542 --------------------------------------------------------------------------
. 2022-12-06 12:42:13.542 WinSCP Version 5.21.6 (Build 12913 2022-11-28) (OS 10.0.17763 - Windows Server 2019 Datacenter)
. 2022-12-06 12:42:13.542 Configuration: nul
. 2022-12-06 12:42:13.542 Log level: Normal
. 2022-12-06 12:42:13.542 Local account: XXX\SQL_ExecJobs
. 2022-12-06 12:42:13.542 Working directory: C:\Windows\system32
. 2022-12-06 12:42:13.542 Process ID: 11960
. 2022-12-06 12:42:13.557 Ancestor processes: ISServerExec, ...
. 2022-12-06 12:42:13.557 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /ini=nul /script="D:\XXX\YYY\ScriptFiles\XXX.txt" /log="D:\XXX\YYY\LogFiles\XXX.txt"
. 2022-12-06 12:42:13.557 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 2022-03-13, DST End: 2022-11-06
. 2022-12-06 12:42:13.557 Login time: December 6, 2022 12:42:13 PM
. 2022-12-06 12:42:13.557 --------------------------------------------------------------------------
. 2022-12-06 12:42:13.557 Script: Retrospectively logging previous script records:
> 2022-12-06 12:42:13.557 Script: option batch abort
< 2022-12-06 12:42:13.557 Script: batch           abort
> 2022-12-06 12:42:13.557 Script: option confirm off
< 2022-12-06 12:42:13.557 Script: confirm         off
> 2022-12-06 12:42:13.557 Script: open ftps://XXX:***@FTPNAME/ -certificate="XXX"
. 2022-12-06 12:42:13.557 Session name: XXX@FTPNAME (Ad-Hoc site)
. 2022-12-06 12:42:13.557 Host name: FTPNAME (Port: 990)
. 2022-12-06 12:42:13.557 User name: XXX (Password: Yes, Key file: No, Passphrase: No)
. 2022-12-06 12:42:13.557 Transfer Protocol: FTP
. 2022-12-06 12:42:13.557 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2022-12-06 12:42:13.557 Disable Nagle: No
. 2022-12-06 12:42:13.557 Proxy: None
. 2022-12-06 12:42:13.557 Send buffer: 262144
. 2022-12-06 12:42:13.557 UTF: Auto
. 2022-12-06 12:42:13.557 FTPS: Implicit TLS/SSL [Client certificate: No]
. 2022-12-06 12:42:13.557 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2022-12-06 12:42:13.557 Session reuse: Yes
. 2022-12-06 12:42:13.557 TLS/SSL versions: TLSv1.0-TLSv1.3
. 2022-12-06 12:42:13.557 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2022-12-06 12:42:13.557 Cache directory changes: Yes, Permanent: Yes
. 2022-12-06 12:42:13.557 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2022-12-06 12:42:13.557 Timezone offset: 0h 0m
< 2022-12-06 12:42:13.573 Script: Connecting to FTPNAME:990 ...
. 2022-12-06 12:42:13.573 Connecting to FTPNAME:990 ...
. 2022-12-06 12:42:13.573 Connected with FTPNAME:990, negotiating TLS connection...
. 2022-12-06 12:42:13.620 Verifying certificate for "XXX" with fingerprint XXX and 18 failures
. 2022-12-06 12:42:13.620 Asking user:
. 2022-12-06 12:42:13.620 **The server's certificate is not known. You have no guarantee that the server is the computer you think it is.**
. 2022-12-06 12:42:13.620 Server's certificate details follow:
. 2022-12-06 12:42:13.620 Issuer:
. 2022-12-06 12:42:13.620 - Organization: XXX, I.T., certificate1, informationtechnology@XXX.com
. 2022-12-06 12:42:13.620 - Location: CA, ON, Toronto
. 2022-12-06 12:42:13.620 Subject:
. 2022-12-06 12:42:13.620 Valid: 2022-07-12 2:39:20 PM - 2023-07-12 2:39:20 PM
. 2022-12-06 12:42:13.620 Fingerprints:
. 2022-12-06 12:42:13.620 - SHA-256: XXX
. 2022-12-06 12:42:13.620 - SHA-1: XXX
. 2022-12-06 12:42:13.620 Summary: Self-signed certificate. The error occurred at a depth of 1 in the certificate chain.
. 2022-12-06 12:42:13.620 Certificate was not issued for this server. You might be connecting to a server that is pretending to be "FTPNAME".
. 2022-12-06 12:42:13.620 If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
. 2022-12-06 12:42:13.620 Continue connecting and store the certificate? ()
< 2022-12-06 12:42:13.620 Script: The server's certificate is not known. You have no guarantee that the server is the computer you think it is.
< 2022-12-06 12:42:13.620 Server's certificate details follow:
< 2022-12-06 12:42:13.620 Issuer:
< 2022-12-06 12:42:13.620 - Organization: XXX, I.T., certificate1, informationtechnology@XXX.com
< 2022-12-06 12:42:13.620 - Location: CA, ON, Toronto
< 2022-12-06 12:42:13.620 Subject:
< 2022-12-06 12:42:13.620 Valid: 2022-07-12 2:39:20 PM - 2023-07-12 2:39:20 PM
< 2022-12-06 12:42:13.620 Fingerprints:
< 2022-12-06 12:42:13.620 - SHA-256: XXX
< 2022-12-06 12:42:13.620 - SHA-1: XXX
< 2022-12-06 12:42:13.620 Summary: Self-signed certificate. The error occurred at a depth of 1 in the certificate chain.
< 2022-12-06 12:42:13.620 Certificate was not issued for this server. You might be connecting to a server that is pretending to be "FTPNAME".
< 2022-12-06 12:42:13.620 If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
< 2022-12-06 12:42:13.620 Continue connecting and store the certificate?
. 2022-12-06 12:42:23.625 Answer: Cancel
. 2022-12-06 12:42:23.625 Peer certificate rejected
. 2022-12-06 12:42:23.625 Disconnected from server
. 2022-12-06 12:42:23.625 Connection failed.
< 2022-12-06 12:42:23.625 Script: Connection failed.
< 2022-12-06 12:42:23.625 Peer certificate rejected
< 2022-12-06 12:42:23.625 Disconnected from server
< 2022-12-06 12:42:23.625 Connection failed.
Hospital
Re: Connection Failure to Certificate
HI,
Thank you for your help.
The code and the value for the certificate was generated as mentioned.
I'm not sure I understand your response.
So is the problem solved or not? If not, please post logs with the certificate fingerprints NOT masked out (it's NOT sensitive information).
