Remove F10 for Quit Hotkey or Customization of Command Hotkeys
Will it be possible to change the default keyboard shortcuts?
If not, is it possible to remove the "Quit" function from the
F10 key? It is located next to the frequently used F9 (properties of selected files) and I miss it very often, which causes the program to close.
