Force RSA-SHA2 Host Key Exchange
I am trying to get WinSCP 5.21.6 to use RSA-SHA2. I have moved up the RSA algorithms in Advanced -> SSH -> Key Exchange tab for the session properties.
It still will only connect at ssh-rsa 2048. I have cleared keys, but it didn't change anything.
Is there a way to force/limit/select which protocols I want to use in the client?
Thank you.
Thank you.
