Simple Synchronize Script
                I am trying to synchronize files from remote to local and having some issues getting the bat file to work.
I currently have it setup like this:
When running this in command line and looking at the log file, I get this:
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /log="C:\Temp\WinSCP Logs\WinSCP.log" /ini=nul ^ /command ^ "open sftp://user:password@secureftp.domain.com/ -hostkey=""hostkey""" ^ "synchronize remote C:\Users\User1\Desktop\SychronizedFolder //servername/Test1" ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT%
. 2023-01-05 13:25:58.919 Real path is '/F:/Test1' . 2023-01-05 13:25:58.919 Startup conversation with host finished. < 2023-01-05 13:25:58.919 Script: Session started. < 2023-01-05 13:25:58.919 Script: Active session: [1] user1@secureftp.domain.com > 2023-01-05 13:25:58.919 Script: synchronize remote C:\Users\User1\Desktop\SychronizedFolder //liv-ft1/Test1 < 2023-01-05 13:25:58.920 Script: Comparing... . 2023-01-05 13:25:58.920 Collecting synchronization list for local directory 'C:\Users\User1Desktop\SychronizedFolder' and remote directory '//servername/Test1', mode = Remote, params = 0x2 (NoConfirmation), file mask = '' * 2023-01-05 13:25:58.921 (EOSExtException) Error retrieving file list for "C:\Users\user1\Desktop\SychronizedFolder\*.*". * 2023-01-05 13:25:58.921 System Error. Code: 3. * 2023-01-05 13:25:58.921 The system cannot find the path specified . 2023-01-05 13:25:58.921 Asking user: . 2023-01-05 13:25:58.921 Error listing directory 'C:\Users\user1\Desktop\SychronizedFolder\*.*'. ("Error retrieving file list for ""C:\Users\user1\Desktop\SychronizedFolder\*.*"".","System Error. Code: 3.","The system cannot find the path specified") < 2023-01-05 13:25:58.921 Script: Error listing directory 'C:\Users\user1\Desktop\SychronizedFolder\*.*'. < 2023-01-05 13:25:58.921 Script: Error retrieving file list for "C:\Users\user1\Desktop\SychronizedFolder\*.*". < 2023-01-05 13:25:58.921 System Error. Code: 3. < 2023-01-05 13:25:58.921 The system cannot find the path specified . 2023-01-05 13:25:58.923 Answer: Abort < 2023-01-05 13:25:58.923 Script: Error listing directory 'C:\Users\user1\Desktop\SychronizedFolder\*.*'. < 2023-01-05 13:25:58.923 Error retrieving file list for "C:\Users\user1\Desktop\SychronizedFolder\*.*". < 2023-01-05 13:25:58.923 System Error. Code: 3. < 2023-01-05 13:25:58.923 The system cannot find the path specified . 2023-01-05 13:25:58.924 Script: Failed . 2023-01-05 13:25:58.924 Script: Exit code: 1 . 2023-01-05 13:25:58.924 Closing connection. . 2023-01-05 13:25:58.924 Sending special code: 1 . 2023-01-05 13:25:58.927 Main session channel closed . 2023-01-05 13:25:58.927 All channels closed
