Task scheduling
True Photo
Zug Switzerland
Task scheduling
Hi
I'm trying to establish a cron job in the Windows 11 Task Scheduler. It should open the remote server (trueprojekte.com) at the root (/httpdocs/foto) and connect to the local folder (E:\foto) and then do the synchronization from the remote server towards E:\foto.
Til now I only did simple jobs in the scheduler, this one is too complicated for me. Would anybody be so kind and describe it for me?
Thomas
(using the latest version of WinSCP on Windows 11 actual version)
Reply with quote E-mail
True Photo
Zug Switzerland
Hi Martin
Believe me, before I posted here I tried out all instructions you propose me – for example first I installed an ssh-rsa key in ssh/authorized_keys and ssh/Kown_hosts and then I tried a bat file:
open sftp://user:thomas_rubin@Trueprojekte.com/ -hostkey="ssh-rsa 1024 SHA256:zUuCjtsADWTct5/GqA0z0rRpBIxxxxxxxxxxxxx th-ru@HP"
# Change remote directory
cd /httpdocs/foto/blogs
# Download file to the local directory E:\foto\blogs
get Leancanvas_Bildschoen.pdf E:\foto\blogs
# Disconnect
close
# Exit WinSCP
On the screen WinSCP flashes for less than a second and then nothing happens, Leancanvas_Bildschoen.pdf is not transferred. When opening WinSCP again, it starts at .../blog
That's why I asked for help and hope now, you tell me where the bug is
Mister H
I think your open command is wrong. You have:
open sftp://user:thomas_rubin@Trueprojekte.com/...
It should be:
open sftp://thomas_rubin:PASSWORD@Trueprojekte.com/...
