Copy command in a batch file: Connection lost
DKKABG
Germany
If a few hundred files are to be transferred, the transfer stops after about 50 files and then continues.
Connection lost.
Connection to remote computer lost.
What is the reason?
How to avoid this effect?
Re: Copy command in a batch file: Connection lost
Hard too tell. But it's not that unusual that network connections are interrupted. In any case, WinSCP should reconnect automatically.
If you want more specific answer or if the reconnect does not happen/work, please attach a full session log file showing the problem (using the latest version of WinSCP).
