Transferring files suddenly wants to create folders
Michele654
I've been doing my workflow the same way forever. Today, I received an Error Code 4, failure to create folder, when trying to transfer *.htm and *.xml files.
Windows desktop -> CentOS 7 server
I have write permission for the existing files on the server. I update them every day on my laptop, then transfer them to the server. The transfer works even though it returns an error code 3 (unable to set time/date) because I am in a group that has write permission.
This morning the transfer failed with the error code 4. I tried to transfer to a directory I have complete permissions for and it does indeed create a folder with the file name, then fails because there's no files (because it's not a folder, it's a file).
I can't figure out why today it wants to copy the files as folders...
Michele654
Moving from mapped drive on Synology NAS was the problem
I solved my own issue.
The problem occurs when I try to move the files from a mapped drive on a Synology NAS. Because the drive is synced to my computer, I can go to c:/Users/(name)/SynologyDrive/(drive name)/folders/file and that works, but if I go to M:/folders/file it doesn't work.
I'm not sure why the "local" file (C: drive) works, but not the mapped drive, but glad to realize the issue and move on!
