File 100% in Log
shelley.ford@...
File 100% in Log
This is just a general question regarding information in the logs. We have a file transfer automation tool that we use with WinSCP. We see when there is a file transfer issue, it looks as though the file has downloaded even though it hasn't. Below is an example where filename was attempted to be downloaded, but wasn't available at the source; however it shows the file size, the kilobytes per second, and file format. What does the 100% mean?
Starting the session...
Session started.
Active session: [1] session name
local path
Using configured transfer settings different from factory defaults.
filename              |         259 KB |  297.3 KB/s | binary | 100%
Can't get attributes of file 'filename'.
No such file or directory.
Error code: 2
Error message from server (en): No such file.
Re: File 100% in Log
