Request to display host name on the title of the Terminal
tojiamathew.work@gmail.com
US
If am remoting into a device via ssh, I will mostly use an IP (Ex: 192.168.0.12)
So if am remoting into multiple devices and open terminals for the multiple remote devices to do some active remotely, there is not way to know from the terminal title to which remote device does the terminal belongs.
So make it more friendly and easy, can you display the IP address on the Title of the terminal?
If there is multiple terminals opened for the same device, then you can display "192.168.0.12 - 1", "192.168.0.12 - 2" etc.
Thank you
Re: Request to display host name on the title of the Terminal
This looks like a PuTTY feature request. Not WinSCP. Or is this about opening PuTTY from WinSCP?
