Delete Remote files without deleting remote folder locations
sreyes
California
I am trying to create a command that will delete files over 180 days old from a directory without deleting the subfolders. I have created the following command line, but it is constantly deleting the sub-folders.
"[[WinSCP]]\WinSCP.exe" /log="L:\Sergio\Logs\UECUtest.log" /ini=nul /command "open sftp://sreyes:Yuri0922%21@172.29.222.123/ -hostkey=""ecdsa-sha2-nistp256 256 9+2BeP7RkAVy3f6NPWlQVCPx94raY9fGud+hLGrfiWY""" "rm /cr/dbhome/D0096T31/import/*<180D" "exit"
The folders are structured as follows:
/cr/dbhome/D0096T31/import/test1/
/cr/dbhome/D0096T31/import/test2/
/cr/dbhome/D0096T31/import/test3/
/cr/dbhome/D0096T31/import/test4/
/cr/dbhome/D0096T31/import/test5/
I have attempted to use a -filemask but to no success. Any guidance is greatly appreciated.
Re: Delete Remote files without deleting remote folder locations
WinSCP cannot ignore subfolders with the rm command.
But if the files you are deleting have specific extension(s), you can limit deleting to that extension(s):
rm /cr/dbhome/D0096T31/import/*.ext<180D
Otherwise you will have to use a more powerful language. Like a PowerShell script with use of WinSCP .NET assembly.
