WinSCP from Wine Linux
Re: WinSCP from Wine Linux
In general this should be working in Wine. I haven't seen a report of such problem before. But I cannot help further. You better seek a help at Wine.
irezvin
This bug was introduced in recent version(s) of Wine
To use WinSCP, you can try using PlayOnLinux and install it using older Wine version (Wine 4.8 worked OK)
EdP
Now I know why
I've been using WinSCP under Wine for years too and usually it's fine, but from time to time, it just hangs upon starting WinSCP. Thanks to this wincfg trick, I think I've figured out what is going on when it hangs. I changed the config to use Windows XP mode for the WinSCP that I have (6.3.3) and bingo! it starts and the first thing it says is: New version released, Upgrade/Close/Help. So I guess it was just freezing on user input never arriving, because I never knew it was asking me something.
