Host "User" does not exist.
fsanch432
Madrid
When I execute the following command in my cmd console, I receive an error. But if I write open in WinSCP console using the same data user, pass and host I can connect with SFTP server.
C:\Program Files (x86)\WinSCP>
C:\Program Files (x86)\WinSCP>WinSCP.com /command "open sftp://usuarioupl:xxxxxxxx@ip.ip.ip.ip:22/"
Searching for host...
Host "usuarioupl" does not exist.
Could you help me?
Re: Host "User" does not exist.
I cannot reproduce that. Please attach a full session log file showing the problem (using the latest version of WinSCP).
