After downloading files using WinSCP – delete files that were downloaded from the remote server
ecuso100
I currently have a WinSCP script which uses synchronize. I would like to change it so that it downloads any files it sees from the remote server path, and then very importantly, it needs to delete the files from the remote server which it just downloaded. If a new file came in to the remote server path during the interval between the download and the delete command, then that new file must not be downloaded – only the files that were successfully downloaded must be deleted from the remote server. Is this possible and can it be scripted? Any assistance is much appreciated.
Here is the script:
@echo off
cls
:SetFileLogVariables
SET localdir=C:\Users\User1\Received
SET remotedir=\folder_1
SET logfile=C:\Users\Users1\Logs\Syncanddelete.log
:SetPrgVariables
SET prgwinscp=C:\Users\Users1\AppData\Local\Programs\WinSCP\WinSCP.com
SET winscplogin="SyncandDelete"
SET winscpfile=%temp%\~tmpWinSCPFTPSyncT_%~N0.txt
IF EXIST "%winscpfile%" DEL /Q /F "%winscpfile%"
:SetWinSCPSyncCommand
REM synchronize command: https://winscp.net/eng/docs/scriptcommand_synchronize
SET ftpcmd=synchronize local -delete -mirror "%localdir%\"
:ftpout
>>"%logfile%" ECHO.
>>"%logfile%" ECHO ***************************  FTP OUT  ***************************
>>"%logfile%" ECHO Synchronizing files to %winscplogin% server  on %date% at %time%
>>"%winscpfile%" ECHO option batch on
>>"%winscpfile%" ECHO option confirm off
>>"%winscpfile%" ECHO option transfer binary
>>"%winscpfile%" ECHO open %winscplogin%
>>"%winscpfile%" ECHO cd "%remotedir%"
>>"%winscpfile%" ECHO %ftpcmd%
>>"%winscpfile%" ECHO close
>>"%winscpfile%" ECHO exit
>>"%logfile%" ECHO %winscpfile%
TYPE "%winscpfile%" >> %logfile%
>>"%logfile%" ECHO -------------------------------------------
"%prgwinscp%" /script="%winscpfile%" >>"%logfile%" 2>&1
>>"%logfile%" ECHO Transmission complete on %date% at %time%
ping -n 2 -w 1000 127.0.0.1 > nul
