Keeping a connection open while running PowerShell commands
                Hi all,
I'm creating automation where we download files from an SFTP, do various PowerShell commands on the data retrieved, wait 3 minutes and do the same thing again.
However, I want to be able to keep the connection to the server open indefinitely while I then query the SFTP every 3 minutes.
I want to achieve this by using a
I do not want to keep creating a connection/logging into the SFTP we have as I feel our firewall may pick this up as potentially unwanted behaviour.
My basic idea is
Apologies if this isn't clear enough
Is this possible?
do/while loop in PowerShell that executes every 3 minutes.
My basic idea is
## Keep connection open [TESTING] & "C:\Program Files (x86)\WinSCP\WinSCP.com" ` /log="FILEPATH" /ini=nul ` /command ` "open sftp://Name[IP]/ -hostkey=`"`"[Key]`"`" -privatekey=`"`"C:\TEST`"`"" ` "cd /Outbound" ` # Keep getting files every 3 minutes DO WHILE [ GET DATA ] [ DO SOMETHING WITH DATA ] FINALLY "exit"
Is this possible?
