Large remote directory sync keeps stopping
thefish324
I am trying to sync an admittedly large directory structure (57 GB, 38K files, 2K sub-directories) with a remote NAS over FTPS.
Everything connects fine and the process starts. It runs for quite some time but always quits like this. Any ideas what could be going wrong?
Re: Large remote directory sync keeps stopping
