To disable Drag & Drop option
PranithaEva
HYD
Hi Team,
We would like to completely disable Drag & Drop option? could you help us with that.
Attaching the picture and highlighted the options that needs to be disabled?
Pranitha
PranithaEva
HYD
We want to disable it as it allows users to download directly and it might require a restart?
Could you let us know if my above understanding is wrong ? And how this feature works?
Pranitha
Sorry, I do not understand. What might require restart? What do you mean by "allows users to download directly"? What's the problem with it?
PranithaEva
HYD
I am presuming that this feature would allow users to download directly from internet.
Pranitha
The very purpose of WinSCP is downloading/uploading files from/to Internet/servers. No matter if user uses drag&drop, keyboard shortcut, toolbar buttons, menus or whatever method they like. I do not understand your question.
