Encryption of the password for CLI use
Individuum
I am currently using the CLI function to push files to a server with the following script:
@echo off
set server=server-ip
set user=user
set pass=password
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command "open sftp://%user%:%pass%@%server%/" "put -neweronly D:\VeeamBackup\Job\* /mnt/backup_user_001/" "exit"
Unfortunately, the logins are in plain text.
Is there a way to write the password in encrypted form, for example in the registry or in a text file, and to decrypt the entry when the script is executed and use it at the appropriate place in the script?
I have already read the article on "Using WinSCP scripting". However, the login details are still in plain text in the file.
How can I hide the plain text / encrypt the plain text?
Yes, I had already seen that.
However, the configuration file in which the login details are located must be somewhere and there are plain text details in it.
Ok, then I do not understand your question. The article explains that what you ask for is technically not possible.
