Scripting does not use standalone parameters
KonerDev
If I type
winscp The5Craft /upload file.txt
I get the message
Scripting does not use standalone parameters. The parameters you have specified on command-line will not be used. Your command-line syntax is probably wrong.
What did I do wrong?
Re: Scripting does not use standalone parameters
Well, we do not know what you wanted to do.
Did you wanted to automate a GUI upload?
Or did you actually want to use console/command-line scripting for the upload?
