WinSCP and Two Factor Authentication With One Time SMS Password
wecanseeformiles
Warwickshire
I'm successfully connecting to a password protected SFTP site using the WinSCP GUI and also with a WinSCP Session in Excel VBA. However the client wants me to turn on at the SFTP site two factor authentication which sends a further one time code by SMS. I've done this and have no problems accessing the SFTP site via browser after logging in and entering the one time code that's SMS'd to me. I've searched your docs and have played around with both the GUI and the Excel VBA code but have no idea how to configure WinSCP to generate a further dialog box that allows entry of the one time code that's sent by SMS. For reference my VBA code is below. I've seen some suggestion that mySession.executecommand("AUTHTYPE") will generate some useful information but I can't even succeed in opening the session.
'PROC NAME:
'VerifyFTPConnection
'DESCRIPTION & COMMENTS:
'Returns True if WinSCP.Session successfully established to SFTP server and returns opened sftp session to calling routine.
'PARAMETERS:
'sessionOptions: session options for sftp session
'mySession: sftp session we are trying to open up
'strUser: user id for sftp session
'strPass: password for sftp session
Public Function VerifyFTPConnection(ByRef sessionOptions As WinSCPnet.sessionOptions, ByRef mySession As WinSCPnet.Session, _
    ByVal strUser As String, ByVal strPass As String) As Boolean
On Error GoTo ErrorHandler
    Dim authType As String
    With sessionOptions
        .Protocol = Protocol_Ftp
        .hostname = "files.*******.com"
        .UserName = strUser
        .Password = strPass
       ' .PortNumber = 21
        .FtpSecure = FtpSecure.FtpSecure_Explicit
    End With
    mySession.Open sessionOptions
    'authType = mySession.executecommand("AUTHTYPE")
    'Debug.Print authType
    VerifyFTPConnection = True
    Exit Function
ErrorHandler:
End Function
Re: WinSCP and Two Factor Authentication With One Time SMS Password
WinSCP .NET assembly does not support interactive authentication prompts.
Are you even able to connect with WinSCP GUI? What do you mean by "have no problems accessing the SFTP site via browser"? Do you mean "web browser"? The web browsers do not support SFTP.
Btw, you wrote about SFTP, but the code uses FTP.
