Vertically align local and remote files by name in Commander?
MetaEd
MetaEd avatar
In the Commander mode, when using sychronized browsing, is there some way to vertically align local files (left-hand side) with remote files (right-hand side) having the same filename? This is a feature I've looked for in the documentation but could not find.
Re: Vertically align local and remote files by name in Commander?
Do you mean that as you scroll one panel, the other panel should scroll to the same files?
MetaEd
MetaEd avatar
I mean, when a file only exists locally, or only exists remotely, a blank row is left in the other pane. Consider a directory containing five files, where file two only exists remotely and file four only exists locally. This would look like:
LOCAL  REMOTE
one    one
       two
three  three
four
five   five
Sometimes they fool you by walking upright.
