Can you display time on server under changed date like is shows on the left?
jlaezza
Florida
Just looking to see if we can display the time the files are changed on the server side?
Re: Can you display time on server under changed date like is shows on the left?
I'm not sure I understand. Both local and remote file panels show file modification time.
https://winscp.net/eng/docs/ui_file_panel
If yours do not, you might have hidden the respective column by mistake (or maybe your other columns are too wide so they move the Changed columns out of the view).
See https://winscp.net/eng/docs/ui_file_panel#selecting_columns
