PowerShell Email Results
Hi -
I'm sure this is totally elementary but I'm not seeing it. Hopefully my struggle can benefit other newbies. The issue I'm having is that I would like to send a different email based on success or failure of the transfer.
I have several PowerShell scripts running to automate uploads/downloads/and create archives. A couple scripts are sending email notifications using Office365.
In this case, I'm getting output on the screen but no email.
Here is part of the script.
Here is the output on the screen. I changed the destination to be read-only to force an error. So the output looks like what you would expect. But since I'm running from a scheduled task, I don't need or want the screen output, just the email.
# Connect $session.Open($sessionOptions) # Set up transfer options $transferOptions = New-Object WinSCP.TransferOptions -Property @{ ResumeSupport = New-Object WinSCP.TransferResumeSupport -Property @{ State = [WinSCP.TransferResumeSupportState]::Off } } # Transfer files $session.PutFiles("C:\SFTPUpload\itadmin\RRD\*", "/*", $False, $transferOptions).Check() } finally { $session.Dispose() } { # Throw on any error $transferResult.Check() Send-MailMessage -From $From -To $To -Subject $SubjectGood -Credential ($Creds) -Body $BodyGood -SmtpServer $SMTPServer -UseSsl -Port 587 } { # Disconnect, clean up $session.Dispose() } exit 0 catch { Send-MailMessage -From $From -To $To -Subject $SubjectBad -Credential ($Creds) -Body $BodyBad -SmtpServer $SMTPServer -UseSsl -Port 587 }
***********Successful ***************** PS C:\Scripts> C:\Scripts\Test\Test KS 2.ps1 # Throw on any error $transferResult.Check() Send-MailMessage -From $From -To $To -Subject $SubjectGood -Credential ($Creds) -Body $BodyGood -SmtpServer $SMTPServer -UseSsl -Port 587 # Disconnect, clean up $session.Dispose() PS C:\Scripts> **************Error ********************************* PS C:\Scripts> C:\Scripts\Test\Test KS 2.ps1 Exception calling "Check" with "0" argument(s): "Cannot overwrite remote file '/230425090309.txt'.$$ Press 'Delete' to delete the file and create new one instead of overwriting it.$$ Permission denied. Error code: 3 Error message from server (en): Permission denied." At C:\Scripts\Test\Test KS 2.ps1:46 char:5 + $session.PutFiles("C:\SFTPUpload\itadmin\RRD\*", "/*", $False, $t ... + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: (:) [], MethodInvocationException + FullyQualifiedErrorId : SessionRemoteException # Throw on any error $transferResult.Check()
