File transfer with queue
LevexKroyt
Good day! Is it possible to transfer multiple files at the same time using the get command ?
My problem is that I need to receive hundreds of small files in a short time, literally 10 bytes each.
And if you just do it with the get command, then the files are transferred one by one.
