WinSCP connection failed
awadoothsingh.thakur@external.epiroc.com
Current version of WinSCP is 5.21.6
When request is initiated it is throwing error
Failed to create target sftp client: WinSCP process terminated with exit code -1073741502 (C0000142).
So please suggest some appropriate solution for the above issue.
Re: WinSCP connection failed
We need way more details. How exactly are you using the assembly? Can you post debug and session log files?
