Add the LOCAL and REMOTE directories in the Session area
samz
Dear Dev Team,
Please, can you add* the LOCAL and REMOTE directories in the Session area of the Login/Site manager window?
*Or move from the Advanced Site Settings window
Regards,
Sam
Re: Add the LOCAL and REMOTE directories in the Session area
What is your use case?
What is the difference between your "add" and "move" suggestions?
samz
A : window LOGIN in my screenshot.
B : window ADVANCED SITE SETTINGS in my screenshot.
Fields : Remote and Local directory fields in my screenshot.
Move: Remove the fields in window B and add them in window A (session area).
Add: Just add the fields in window A (session area), to edit them without going to window B.
I would like to edit the fields directly in the window A (session area).
Thanks and regards.
I understand that you want to edit the directories on the Login dialog. But why do you need to edit those fields so often, that it would justify moving specifically those two (out of dozens of other fields) to the Login dialog.
samz
Hello Martin,
It's not a big deal, I would just:
  • View (and edit*) the pair of linked directory without diving in the Advanced window.
  • View the most important data for a site item.
*When I have to rename the directories.
Thank you and regards
wmubrown
MI
I'd also like to see source/remote directories in the session window and bump this request up a peg
I think it would be helpful to all users to see what directories the configuration will take them to - source and destination. My destination changes every month as I need to keep monthly data ingestion files together and the steps necessary to update destination directory is a bit irksome. Also, because I connect to several remote server directories depending upon the task i am working on, I have several saved sessions just to point to the correct source/destination folders - I'd like to see that before I connect to confirm in my mind I am going to the correct locations before connection is made and directories are shown. Thanks! LOVE WinSCP!
