Error at disconnecting/closing session
jruiz
I have a customer that has FileZilla Pro Enterprise Server (Windows) with 1.7.0 version (latest). At the time on closing connection to this server using SFTP it gives an error.
I have did some testing with different SFTP clients and WinSCP is the only one that gives an error.
I tried these SFTP clients: WinSCP 6.1 – Cyberduck 8.6.0 – FileZilla 3.64.0
With WinSCP when I close the connection it gives this error:
Connection has been unexpectedly closed.
Server sent command exit status 128.
(I attach logs.)
With Cyberduck and FileZilla I don't see any errors. I attach logs too.
On server side with debug mode I see this "error" when closing connection (it gives the same log using different SFTP clients):
SFTP session failed [result=general function failure, error=no error]
But it says "error=no error" so I guess there is no error on server side 😐.
Someone can help, please?
Greetings.
Re: Error at disconnecting/closing session
