Click in ACCEPT button with /synchronize
dsilver23
I'm trying to create an script that automatize the download of the changes in my ftp folder to a local folder
I try this:
winscp.exe "estelfitxers" /synchronize local_folder ftp_folder
But then, the winscp.exe opens and show me the screen with my parameters in the header but I always need to click in ACCEPT button.
How can I execute with the accept button included?
Thanks a lot.
Edward
dsilver23
thanks Martin
Thanks for the answer. It solved my issue... but now when the task finish if there's no files to synchronize always appears a box "No differences found" and I have to close it manually
have you got any idea to not appear this box or how to close it auto?
thanks Martin!!!
