409 conflict when uploading files
Axel_RT
Reutlingen (Germany)
I have installed the WinSCP, Version is 6.1
Connected via WebDAV to our Nextcloud.
Always when I start the session from the desktop – it works fine.
I am always able to upload files (drag & drop).
But I have created a session in C# too
(using "WinSCP.exe" and "WinSCPnet.dll" from the same version 6.1).
In this case – the connection also seems to work.
Because the command session.Open(options) shows NO error.
But when this command is being executed
result = session.PutFiles(myLocalPath + myFileName, myRemotePath, false, transferoptions);
the error "409 conflict" occurs.
Here is the imoportant part of my code:
public ClassWinSCP(string thepath,string thefilename)
    myLocalPath = @"L:\ITORG\2_Teamassistenz, Verwaltung\Teammitglieder\\goede\_AKTUELL\";
    myFileName = "*";
    string myRemotePath = "/nextcloud/public.php/webdav";
    string myLogfile = "Nextcloud-Upload.log";
    string myLogPath;
    Session session = new Session();
    SessionOptions options = new SessionOptions();
    TransferOptions transferoptions = new TransferOptions();
    TransferOperationResult result;
    myLogPath = myLocalPath + myLogfile;
    session.DebugLogPath= myLogPath;
    options.Protocol = Protocol.Webdav;
    options.HostName = "myserver";
    options.PortNumber= 9999;
    options.Secure= true;
    options.RootPath= myRemotePath;
    options.UserName = "XXXXXXXXX";
    options.Password = "YYYYYYYYY";
    session.Open(options);
    transferoptions.TransferMode = TransferMode.Binary;
    result.Check();
Thanks for help!
Sincerely yours
Axel Goede
Re: 409 conflict when uploading files
Please post full session logs file showing an upload of the same file to the same remote folder, both from GUI and the code.
