WinSCP Powershell Module Upload failed run in background Windows Server
wilsonwen
Hi, schedule my PowerShell script with Windows Server Task scheduler, and can successfully upload files to SFTP with no issue. However, when Windows Server goes into Ctrl+Alt+Del lock screen mode after 2 hours, Send-WinSCPItem command failed to execute transfer files. Any idea on how to resolve this issue? Thank you.
Import-Module WinSCP
New-WinSCPSessionOption
Send-WinSCPItem
Get-WinSCPChildItem
Remove-WinSCPSession
Re: WinSCP Powershell Module Upload failed run in background Windows Server
WinSCP PowerShell module is a 3rd party package.
Anyway, if you post WinSCP session log file both for working and failing upload, we might be able to help nevertheless.
