"Confirm overwrite remote file" per session
                Hi there,
Thank you for your efforts with this project - a great tool that many enjoy using.
If possible, could I propose a feature request where with the drop-down responses for Yes (Yes, Yes to All, Newer Only) for the Overwrite remote file dialog box, that there might be a fourth option with Yes for Session.
The rationale for this is that you may want to repeatedly send a file (after updates during programming, etc.) and not want to keep seeing the dialogue box within this session, but not want to select "Yes to All" and change the overall default overwrite behavior for the application.
Thank you,
Paul
Thank you,
Paul
