WinSCP on windows with AD
phill123
Hi, Is the WinSCP on Windows Server can be used with AD, so without create local user I need to used LDAP, is this feature supported on WinSCP, if not can you please support if there is workaround to use LDAP with it.
Re: WinSCP on windows with AD
Sorry, I do not understand what you ask for. Do you have a problem with using WinSCP in your environment? If you have, please post logs files or error you are getting.
