Local folder pane empty and directory cannot be changed
JamesEdmondsUKPN
England
My WinSCP local folder pane in commander view is not loading a directory when I start the application, and just shows as empty:
Image 1
If I try to change to My Documents or Desktop folders, nothing happens:
Image 2
Any thoughts on why this may be? If I run as a local administrator, they can change to My Documents and Desktop folders, but not C:\.
Description: Cannot change folder
Description: Empty local folder pane
Re: Local folder pane empty and directory cannot be changed
