I cannot just move the .xls.xls file to another folder.
jirapat nuwong
I have a problem I want to check correct file name in Sent folder. If it's incorrect I want to move file to Error folder but I cannot just move the .xls.xls file.
My Coding:
transferResult = session.PutFiles(filePaths[iFile], sessionOptions.RootPath + "/" + fi.Name + "/Error/", false, transferOptions);
session.RemoveFiles(sessionOptions.RootPath + "/" + fileInfo.Name + "/Sent/" + Path.GetFileName(filePaths[iFile]));
how can I fix it?
Thank you,
Nicki.
Re: I cannot just move the .xls.xls file to another folder.
I'm sorry, but I do not understand what you mean by "I cannot just move". Do you get any error? Or what is the problem?
I mean I cannot move file incorrect name.
Ex. I want to move Test.xls.xls in Sent folder to Error folder because it's incorrect file name (Test.xls is correct file name) but it's not move to Error folder.
I'm sorry, but I still do not understand. Maybe the problem would be more clear if you post some logs or screenshots.
