FTP transfer using a batch file
kathan
USA - NJ
I am trying to transfer files from FTP to FTP via a batch file but it loses a few KBs when copying. So, if the file size was 400kb then it would copy 396kb. I have ran the batch file multiple times but I am still experiencing the same issue. I then clicked the option for "Compare Directories" within the software but it "No differences found".
I would also like to verify the copied files using the batch files. Is there a way to do so?
I have attached the code with the post
  • script for winscp.bat (547 Bytes, Private file)
Re: FTP transfer using a batch file
kathan
USA - NJ
I am not sure why it didn't post earlier but here it is.
  • 20230911_112959_Data_to_Data.txt (8.18 KB, Private file)
Description: I am not sure why it didn't post earlier but here it is.
kathan
That is the issue. Even though the files are not transferred correctly, it keeps saying there is nothing to synchronize via the code and the WinSCP software.
