Please add the ability to CHANGE THE FONT SIZE in the panel that shows the different servers
ckcelite
USA
The panel that pops up containing all of the FTP, SFTP, etc servers that you can click and log into. The font is too small. I have poor eyesight. The only information I can find online are people suggesting I change the font size for the entire Windows environment. That's not possible when working on a computer at work, or one that multiple people use.
I have about 25 servers listed in my WinSCP and it's so difficult finding the correct server quickly. Please, can you create a solution to this by allowing people to change the font size directly in the app?
Re: Please add the ability to CHANGE THE FONT SIZE in the panel that shows the different servers
Why cannot you change system font size on your work computer? The settings is user specific, afaik.
