Scripting with use of .ini file
cristian.fuchs@itk-rheinland.de
Germany
We moved our configuration to a new server with new WinSCP 5.21.7
I imported the old ini file and everything is working with the GUI.
But it seems our old scripts refuses by reading the .ini file
WinSCP Version 5.21.7 (Build 12963 2023-01-23) (OS 10.0.20348 - Windows Server 2022 Standard)
Configuration: \\server\c$\Program Files (x86)\WinSCP\winscp.ini
In the new log it shows
 Session name: MGL-XXX-RD-ELIA (Ad-Hoc site)
and it doesn't resolve the host name.
The old log shows
Session name: MGL-CEVAS-RD-ELISABETH (Modified site)
and it resolves the hostname
Somebody an idea?
Re: Scripting with use of .ini file
The INI file cannot cause your script trying to load a different session. Your scripts must have changed. Make sure the script loads the session that matches your INI file.
Germany
Sorry, was a mistake while copy and paste ;)
Old log:
New log
Session name: MGL-MGL-XXX-RD-ELIA (Modified site)
The script doesn't changed. Just an new installation (server and WinSCP)
Germany
New log:
Old log
Session name: MGL-XXX-RD-ELIA (Modified site)
Sorry my mistake. I am not allowed to post the full log.
But it must have something to do that the credentials will not included for the connection in the new installation.
Germany
Full log
. 2023-10-06 08:51:53.317 --------------------------------------------------------------------------
. 2023-10-06 08:51:53.317 WinSCP Version 5.21.7 (Build 12963 2023-01-23) (OS 10.0.20348 - Windows Server 2022 Standard)
. 2023-10-06 08:51:53.317 Configuration: \\msbmcc07\c$\Program Files (x86)\WinSCP\WinSCP.ini
. 2023-10-06 08:51:53.317 Log level: Normal
. 2023-10-06 08:51:53.317 Local account: ITK\controlm
. 2023-10-06 08:51:53.317 Working directory: \\msbmcc07\c$\Program Files (x86)\WinSCP
. 2023-10-06 08:51:53.317 Process ID: 3400
. 2023-10-06 08:51:53.332 Ancestor processes: powershell, cmd, p_ctmam, p_ctmag, ...
. 2023-10-06 08:51:53.332 Command-line: "\\msbmcc07\c$\Program Files (x86)\WinSCP\winscp.exe" /xmllog="C:\Users\controlm\AppData\Local\Temp\wscp1BC4.00184AA1.tmp" /xmlgroups /xmllogrequired /nointeractiveinput /stdout /stdin /dotnet=5.21.7  /ini="\\msbmcc07\c$\Program Files (x86)\WinSCP\WinSCP.ini" /log="c:\temp\MGL-CEVAS-RD-WinSCP-To-ELISABETH_winscp.log"  /console /consoleinstance=_7108_58902858_192
. 2023-10-06 08:51:53.332 Time zone: Current: GMT+2, Standard: GMT+1 (Mitteleuropäische Zeit), DST: GMT+2 (Mitteleuropäische Sommerzeit), DST Start: 26.03.2023, DST End: 29.10.2023
. 2023-10-06 08:51:53.332 Login time: Freitag, 6. Oktober 2023 08:51:53
. 2023-10-06 08:51:53.332 --------------------------------------------------------------------------
. 2023-10-06 08:51:53.332 Script: Retrospectively logging previous script records:
> 2023-10-06 08:51:53.332 Script: option batch on
< 2023-10-06 08:51:53.332 Script: batch           on
< 2023-10-06 08:51:53.332 Script: reconnecttime   120
> 2023-10-06 08:51:53.332 Script: option confirm off
< 2023-10-06 08:51:53.332 Script: confirm         off
> 2023-10-06 08:51:53.332 Script: option reconnecttime 120
> 2023-10-06 08:51:53.332 Script: open "sftp://MGL-XXX-RD-ELIA" -timeout=15
. 2023-10-06 08:51:53.332 Session name: MGL-XXX-RD-ELIA (Ad-Hoc site)
. 2023-10-06 08:51:53.332 Host name: MGL-XXX-RD-ELIA (Port: 22)
. 2023-10-06 08:51:53.332 User name:  (Password: No, Key file: No, Passphrase: No)
. 2023-10-06 08:51:53.332 Tunnel: No
. 2023-10-06 08:51:53.332 Transfer Protocol: SFTP
. 2023-10-06 08:51:53.332 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2023-10-06 08:51:53.332 Disable Nagle: No
. 2023-10-06 08:51:53.332 Proxy: None
. 2023-10-06 08:51:53.332 Send buffer: 262144
. 2023-10-06 08:51:53.332 Compression: No
. 2023-10-06 08:51:53.332 Bypass authentication: No
. 2023-10-06 08:51:53.332 Try agent: Yes; Agent forwarding: No; KI: Yes; GSSAPI: Yes
. 2023-10-06 08:51:53.332 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2023-10-06 08:51:53.332 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2023-10-06 08:51:53.332 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2023-10-06 08:51:53.332 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2023-10-06 08:51:53.332 Simple channel: Yes
. 2023-10-06 08:51:53.332 Return code variable: Autodetect; Lookup user groups: Auto
. 2023-10-06 08:51:53.332 Shell: default
. 2023-10-06 08:51:53.332 EOL: LF, UTF: Auto
. 2023-10-06 08:51:53.332 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2023-10-06 08:51:53.332 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2023-10-06 08:51:53.332 SFTP Bugs: Auto,Auto
. 2023-10-06 08:51:53.332 SFTP Server: default
. 2023-10-06 08:51:53.332 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2023-10-06 08:51:53.332 Cache directory changes: Yes, Permanent: Yes
. 2023-10-06 08:51:53.332 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2023-10-06 08:51:53.332 DST mode: Unix
< 2023-10-06 08:51:53.332 Script: Fernrechner wird gesucht …
. 2023-10-06 08:51:53.332 Looking up host "MGL-XXX-RD-ELIA" for SSH connection
< 2023-10-06 08:51:54.332 Script: Host „MGL-XXX-RD-ELIA“ ist nicht vorhanden.
Germany
Reply Notification - Scripting with use of .ini file
Back from holiday ;)
The problem is coupling the assembly with WinSCP application configuration.
In the old configuration it worked. But on the new server with new WinSCP install it doesn't work. I know that this way is not wanted, but it will be lot of work to switch it all.
so maybe there is still a way to work with our old config.
