Server sent disconnect message type 11 (by application) : user disconnected.
Raveena
Hyderabad
When I am trying to connect to one user id we are getting this error, but we are able to connect with other users to the same host.
Below is the error log, can you please help me on this.
. 2023-10-12 15:40:07.427 Host key matches cached key
. 2023-10-12 15:40:07.430 Initialised AES-256 CBC client->server encryption
. 2023-10-12 15:40:07.430 Initialised HMAC-SHA1 client->server MAC algorithm
. 2023-10-12 15:40:07.430 Initialised AES-256 CBC server->client encryption
. 2023-10-12 15:40:07.430 Initialised HMAC-SHA1 server->client MAC algorithm
! 2023-10-12 15:40:08.158 Using username "XXXXXX".
. 2023-10-12 15:40:15.783 Server offered these authentication methods: publickey,password
. 2023-10-12 15:40:15.783 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2023-10-12 15:40:15.783 Using stored password.
. 2023-10-12 15:40:15.809 Sent password
. 2023-10-12 15:40:16.748 Access granted
. 2023-10-12 15:40:16.748 Opening session as main channel
. 2023-10-12 15:40:17.114 Opened main channel
. 2023-10-12 15:40:19.310 Received disconnect message (by application)
. 2023-10-12 15:40:19.310 Disconnection message text: User Disconnected
. 2023-10-12 15:40:19.310 Server sent disconnect message
. 2023-10-12 15:40:19.310 type 11 (by application):
. 2023-10-12 15:40:19.310 "User Disconnected"
* 2023-10-12 15:40:19.357 (EFatal) Server sent disconnect message
* 2023-10-12 15:40:19.357 type 11 (by application):
* 2023-10-12 15:40:19.357 "User Disconnected"
* 2023-10-12 15:40:19.357 Authentication log (see session log for details):
* 2023-10-12 15:40:19.357 Using username "XXXXXX".
* 2023-10-12 15:40:19.357 Authentication failed.
Re: Server sent disconnect message type 11 (by application) : user disconnected.
Can you connect with any other SFTP client?
Did you check server-side log file?
Raveena
Yes, verified with other users, it is working fine.
Only with this particular user id.
Can you please guide me what checks we can do on this and how to fix it.
Please post log from the other client.
And server-side logs for both WinSCP and the other client, if you can.
