Simple upload fails
Meteosat
South Wales
Simple upload fails
Basic scenario:
I want to load a single file to an IONOS website – previously used WGET. Now set up the excellent WinSCP and console operation on SFTP is fine – so thank you.
But using a simple cmd or bat file opens the connection but won’t add the test file. This is my ultra simple file:
WinSCP.com sftp://u3xxxxxxxx:password@xxx.xxx.xxx.xxx/mrtg
put t1.txt
Running the file opens the connection but doesn’t upload the file. However…..
the DOS box is open and if I now type: put t1.txt – success.
I’m obviously doing something stupid but a little help would be appreciated as I also want to add a delete command for the remote file before adding the latest one.
Cheers,
James
Meteosat
South Wales
Re: Simple upload fails
Thank you. That was helpful and I discovered that late yesterday as well. Actually the log then showed it had failed on authentication and I had to add a pass key manually which IONOS server accepted.
Cheers,
James
