Data connection closed
Good Morning,
Recently, I have experienced repeated failures when attempting to upload a single file nightly using WinSCP. However, I have no problem uploading the same file using FileZilla. Here is a portion of the WinSCP log file:
Any suggestions would be greatly appreciated.
Thank you.
< 2023-10-19 21:05:05.771 200 Binary mode selected. > 2023-10-19 21:05:05.771 PASV < 2023-10-19 21:05:05.802 227 Entering Passive Mode (##,###,##,##,###,###) > 2023-10-19 21:05:05.802 STOR filename.csv . 2023-10-19 21:05:05.802 Connecting to ##.###.##.##:##### ... < 2023-10-19 21:05:05.896 125 Secure data connection open; transfer starting. . 2023-10-19 21:05:10.973 Data connection closed < 2023-10-19 21:05:10.988 425 Can't open data connection. . 2023-10-19 21:05:10.988 Copying files to remote side failed. * 2023-10-19 21:05:10.988 (ExtException) **Copying files to remote side failed.** * 2023-10-19 21:05:10.988 Can't open data connection. . 2023-10-19 21:05:10.988 Asking user: . 2023-10-19 21:05:10.988 Error transferring file 'C:\filefolder\filefolder1\filename.csv'. ("Copying files to remote side failed.","Can't open data connection.") < 2023-10-19 21:05:10.988 Script: Error transferring file 'C:\filefolder\filefolder1\filename.csv'. < 2023-10-19 21:05:10.988 Script: Copying files to remote side failed. < 2023-10-19 21:05:10.988 Can't open data connection. . 2023-10-19 21:05:10.988 Answer: Abort * 2023-10-19 21:05:11.004 (ESkipFile) Error transferring file 'C:\filefolder\filefolder1\filename.csv'. * 2023-10-19 21:05:11.004 Copying files to remote side failed. * 2023-10-19 21:05:11.004 Can't open data connection. . 2023-10-19 21:05:11.004 Copying finished: Transferred: 0, Elapsed: 0:00:05, CPS: 0/s . 2023-10-19 21:05:11.004 Script: Failed . 2023-10-19 21:05:11.004 Script: Exit code: 1 . 2023-10-19 21:05:11.004 Disconnected from server
Thank you.
