File synchronization task features
Mirk0
I tried to find more information in the documentation, but to no avail.
Is it possible to use file synchronization to assign tasks for multiple folders, that you can select which one should be synchronized? I have several rather large folders and I don't want, that WinSCP always needs to check the complete server for changes. FreeFileSync has the ability, but it doesn't work with WebDAV. The target server for synchronization doesn't support FTP.
Re: File synchronization task features
Are those directories somehow related? I mean are they for example subfolders of the same parent folder (but there are other subfolders that you do not want to synchronize)? Or are those just random folders scattered around file system?
Mirk0
As an example, I have 3 parent folders with several layers of sub-folders below. The layers are totaling about 500 folders. I only want WinSCP to sync one of the parent folders each time (3 tasks), not all 3 at once (1 task). Changes often are only made to one of the parent folders.
I hope, that clarifies your question.
