WinSCP NuGet - Does Not Copy WinSCP.exe
I'm using WinSCP via the NuGet package, locally when building the solution (.NET Framework 4.72, multiple projects) the WinSCP.exe is copied to the output folder, however when building via Jenkins the WinSCP.exe does not get copied, only the WinSCPnet.dll.
Is there something I'm missing?
Re: WinSCP NuGet - Does Not Copy WinSCP.exe
Ok, managed to resolve the issue by upgrading the solution from using "packages.config" to PackageReference,
