File Name when using GetFilesToDirectory
I'm working on a PowerShell script to copy files from an SFTP location to a local machine. Everything is working fine, except for some data I want to obtain once the file(s) are transferred.
When I execute the script I see that it is returning an object showing
I'm not sure if I'm missing something or this feature doesn't exist?
Code for transfer:
IsSuccess and FileName. I want to be able to take the returned information and then insert it to a SQL table for later use by another application. I'm able to access the value for IsSuccess but not for FileName (see attachment for output).
Code for transfer:
#Create WinSCP session $WinSCPSession = New-WinSCPSession -SessionOption (New-WinSCPSessionOption -HostName $sftphost -Protocol Sftp -PortNumber $port -Credential $Cred -SshHostKeyFingerprint $sftpfingerprint) #Transfer files to local directory $WinSCPSession.GetFilesToDirectory($sftpDownloadDir,$localDir,'',$deleteRemote) #return $filename $WinSCPSession.close() $WinSCPSession.Dispose()
