PutFiles (SFTP) to mainframe dataset
mvannie9
South Africa
Good day.
I am able to put a file on a mainframe with the interface.
The output is a dataset.
Generated code is this:
    session.Open(sessionOptions);
    session.PutFiles(@"C:\temp\New Text Document.txt", "/FTADV:P=WIN,lrecl=160,recfm=fb/*").Check();
This is the remote location I put in to put the file:
/FTADV:P=WIN,lrecl=160,recfm=fb/___SS.APP.TEST.SOLMIS.CIF856
(As per the attachment.)
It works 100% with the GUI.
When trying the API, it puts the dataset on the default folder when using the API and not the actual dataset.
(Hope this makes sense.)
If someone can push me in the correct direction to configure the API to upload the local (Windows) file as a dataset on a mainframe?
Thank you
Mike
Description: Where it actually puts the file. Default login location, which is wrong
Description: Where it is suppose to be
Description: When uploading a file and specifying the correct parameters and dataset.
