How do I exclude subdirectories in vb? "|*/" not working...
Tesla44289
Germany
Hi!
I'm trying to upload files without also uploading the archive directory located in the same folder as the files, however it's not working the way I expect it to.
transferOptions.FileMask = "*" & tempExt
When I do this the archive subfolder and all files with the previously set temporary extension get copied.
transferOptions.FileMask = "*" & tempExt & "|*/"
But when I do this no files are copied at all...
Re: How do I exclude subdirectories in vb? "|*/" not working...
Your code seems correct. The problem is probably elsewhere.
Maybe something like this:
Exclude Sub Folders
If it does not help, Please attach a full session log file showing the problem (using the latest version of WinSCP).
