Trailing slash in custom command
dan
Paris, France
Is there a way to write into a prompt area,
full path + selected folder (./!), if possible with trailing slash?
rsync -a --delete "!?From:?./!!" "!?To:?!"
Or add a trailing slash to command line "!/!"?
rsync -a --delete "!/!" "!?To:?!"
Re: Trailing slash in custom command
Patterns cannot be used in the default value of a prompt.
Though you can implement such default using shell constructs.
FROM=!?From (keep empty for selected file):! && rsync -a --delete "${FROM:-!/!}" ...
Regarding the other question, you can again use shell tricks like:
rsync -a --delete "!/!" "!?To:?!""/"
