Synchronization Deleting directory
Randy12
Good morning,
I run a job where I sync a remote directory to a local by pulling a CSV the issue is it deletes the directory folder that houses the .csv file.
I am using
synchronize remote -delete -filemask=".csv"
Re: Synchronization Deleting directory
Please attach a full session log file showing the problem (using the latest version of WinSCP). Also, synchronize remote synchronizes local directory to the remote one, contrary to what you wrote.
